starting issues
Old May 19, 2009 | 03:59 PM
jvog's Avatar
jvog
Default starting issues
So sometimes my car just doesn't want to start when its cold. I'll sound like its starting to fire up but it doesn't. Eventually it will start but it takes a few tries. Its only when the engine is cold. If its been ran recently it starts fine. Any ideas?
Old May 19, 2009 | 08:32 PM
jvog's Avatar
jvog
noone
Old May 19, 2009 | 09:24 PM
livefast1's Avatar
livefast1
sure its a hot cold issue? have you done the pprv delete?
Old May 19, 2009 | 09:33 PM
jvog's Avatar
jvog
I dont know what the pprv delete is. But from experience, it always starts when its hot, and only gives me trouble when its cold, but not 100% of the time.
Old May 19, 2009 | 10:04 PM
livefast1's Avatar
livefast1
when you upgraded the fuel pump did you remove the little white valve inline with the pump and the fuel hat?
Old May 20, 2009 | 12:35 AM
jvog's Avatar
jvog
uh no. But the problem hasn't been happening since then. Its only been happening since the weather got warm. The car was tuned in the winter so do you think thats a problem?
Old May 20, 2009 | 01:10 AM
GT Tommy's Avatar
GT Tommy
Default Try this test!
Try this method when starting your engine when it is cold to see if it make a difference. Turn your ignition switch to the on position for 2 to 3 seconds, then try starting your engine. If it starts right up, that may suggest you have a fuel related problem. Let us know what happens. Good luck, Tommy.
Old May 20, 2009 | 07:01 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Sounds like a fuel pressure related problem... Maybe injectors or the rail bleeding off FP overnight.
Old May 20, 2009 | 10:19 AM
jvog's Avatar
jvog
I've tried watching a few seconds before starting it, but that doesn't work either. Thanks though.
I'll check out the fuel rails and everything today to make sure they aren't leaking.
Old May 20, 2009 | 12:59 PM
GT Tommy's Avatar
GT Tommy
Default Fuel pressure gauge install!
To be sure, you should install a fuel pressure gauge on your fuel rail. Your fuel pressure should be between 35 psi and 40 psi with your ignition switch on and engine off, and at idle as well. Good luck, Tommy.
