Quadshock options???
Old May 24, 2009 | 12:08 PM
03GTwhos's Avatar
03GTwhos
Default Quadshock options???
I was wondering if there was any aftermarket Quadshock options for the 2V Gt's like mine? Something maybe solid or better for launching? I haven't looked around much at all.
Old May 24, 2009 | 03:00 PM
ddmsgtr1's Avatar
ddmsgtr1
Get some good aftermarket upper and lower control arms and trash the quadshocks.
Old May 24, 2009 | 04:19 PM
Sxynerd's Avatar
Sxynerd
^Bingo!
Old May 24, 2009 | 04:47 PM
03GTwhos's Avatar
03GTwhos
I took them off and put on some upper and lower CA's on and left them off. I went to the track twice and both times I couldn't heat my tries up cause of bad wheel hopping. I put them back on see if that cures the problem. What do you guys think is causing the bad wheel hoppin?????
Old May 24, 2009 | 05:41 PM
PistolPete79's Avatar
PistolPete79
i put some some blistein quad shocks but i didnt really see any difference at all
Old May 24, 2009 | 05:53 PM
DreamerGT's Avatar
DreamerGT
blistein http://www.maximummotorsports.com/in...roducts_id=971
Old May 24, 2009 | 07:11 PM
ddmsgtr1's Avatar
ddmsgtr1
From my experience with my strange 10ways, if your shocks are too loose it will cause it to hop. Maybe you have a bad shock.
edit: What kind of uca/lca did you install?
Old May 24, 2009 | 08:29 PM
zero2005's Avatar
zero2005
+1 on the uca/lca.
definately consider getting some new adjustable shocks before the extra quadshocks.
Old May 24, 2009 | 10:01 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Go git yourself some UPR poly/spherical LCA's/UCA's and will be able to forgo the quads as mentioned. Will be a bit more NVH than poly/poly ones, but worth it.
Jazzer
Old May 25, 2009 | 08:53 AM
03GTwhos's Avatar
03GTwhos
They are tubluar CA's, like the Summit brand.
