Overheating
Old May 26, 2009 | 11:33 PM
Sidewayz2K's Avatar
Sidewayz2K
Unhappy Overheating
So i picked up my car today..bought it off my brother, and as i was driving around it started to get hot. It's happened b4 and the thermostat was changed, which seemed to solve the problem. It only does it when driving in town (small town, lots of stop signs). It will get hot then go back down to normal, then back up and back down. Could it be the water pump gettin rdy to go?
Old May 27, 2009 | 01:39 AM
JC316's Avatar
JC316
Could be your water pump, or it could be the radiator fan not working. Turn on the A/C and see if the fan kicks on, if it does, then it's working.
Old May 27, 2009 | 02:50 AM
jagass's Avatar
jagass
Damn...Same prob here...
Old May 27, 2009 | 12:56 PM
phorr20's Avatar
phorr20
Don't mean to bust in on your thread sidewayz2k but.....I have a 98 vert auto, and when it gets Africa HOT out here in the desert...my car goes from 1st - 3rd. It's would be like shifting from 1st - 4th on a 5 speed. The shop said its so the motor won't over heat. It's ok at night when the temp is down outside. Getting a alum. radiator today. I hope it works. Any other suggestions on the prob.? Thanks in advance.
Old May 27, 2009 | 06:22 PM
pbshow's Avatar
pbshow
Africa hot? Wow, you must live in Phoenix. Another cause of the overheating might be air in the system. Have a local garage purge your system. It helped on my '98 GT.
Old May 27, 2009 | 09:56 PM
mustangman03's Avatar
mustangman03
sounds like a stopped up radiator or a bad cooling fan
Old May 27, 2009 | 10:24 PM
Donnie's GTS's Avatar
Donnie's GTS
Make sure your fan is kicking on, if you cruise on the highway and it stays cool its probably your fan.
Old May 28, 2009 | 07:05 PM
phorr20's Avatar
phorr20
Got the new radiator in and the fan is working...still doing the same thing. You think I need to up-grade my stock fan? Thanks
Old May 28, 2009 | 10:01 PM
Ford93Bronco's Avatar
Ford93Bronco
I was having the same problem in my bronco. I bought a Cheap thermostat from Auto zone and I think I got a bad one. I bought a different higher quality one and now its working like new again.
Old May 28, 2009 | 10:23 PM
grogan's Avatar
grogan
my car does that aswell..ive got a mishimoto 2 core radiator, twin fans, and 180 t stat. sitting in traffic my guage shows the needle in the middle of the gauge. when cruising it barely gets above the c.
