Jacking Questions
I know to jack up only the rear of the car you use the pumpkin and to jack up the front you use the k member, but what points do you guys use if you only want to jack up 1 tire??
For example to jack up a front tire, is it safe to place the jack right under the spring?
And for the rear, where do you guys put the jack?
https://mustangforums.com/forum/2005...ck-points.html
check this out its an old thread here that I've found helpful and goes over what you're asking and has a diagram too
Yeah, don't ever jack up by the pumpkin. I bent my diff cover doing that, at it's a pain in the *** the replace it.
If I want to get the rear wheels (or anything in the rear, for that matter), I jack up by the rear subframe rails. Put a piece of wood under your jack arm so it doesn't bend the metal, and lift away!
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
