Problems with Idle while operating A/C and Defrost
Old Jun 18, 2009 | 07:37 PM
65mechanic's Avatar
65mechanic
Default Problems with Idle while operating A/C and Defrost
Hi guys pretty much ever since I got my 2000 mustang gt i have been having problems with the air conditioning and defrost. Whenever i turn on either the air conditioning or the defrost the idle starts jumping. The A/C used to blow cold air but still the idle would jump up and down and now it doesnt even blow cold air. I have already tried replacing the Idle Control motor but $92 bucks later and it still doesnt work. The only reason i tried to replace the idle control motor was because my friend and brother were having similar problems and they replaced their idle control motor and then their A/C systems worked fine. I guess im just the unlucky one. Thanks in advance for the help.
Old Jun 18, 2009 | 08:20 PM
StockD15b's Avatar
StockD15b
since it dosent blow cold anymore,have you added freon? if so there might to much.
Old Jun 18, 2009 | 08:39 PM
65mechanic's Avatar
65mechanic
yea, i have added some freon. should i try to take some out?
Old Jun 18, 2009 | 08:50 PM
StockD15b's Avatar
StockD15b
does the freon can you used have a lil pressure guage? its acctually suppost to go by weight and not oz's. but ya id try that first. im no a/c expert tho. so you assume all the risk lol.
Old Jun 18, 2009 | 09:01 PM
mrsinister2424's Avatar
mrsinister2424
Its your AC recycling switch. They're about 20 bucks at the stealership. Just saved you a boat load of cash
I ended up replacing the compressor, lines, accumulator, and freon, and it STILL didn't fix it. Then I replaced the AC recycling switch, boom, 20 bucks, fixed.
The switch sits right on the accumulator(big cylindrical thing next to the firewall). Its got a little plug in it and it just twists off the shraeder valve.
EDIT: BTW, I had teh jumpy idle thing too when I turned on the AC.
Old Jun 18, 2009 | 09:54 PM
65mechanic's Avatar
65mechanic
Awesome, thanks. Do you think the local parts store would have one?
Old Jun 19, 2009 | 08:30 PM
mrsinister2424
Maybe, maybe not. Just go to the dealership. Its only like 20 bucks, and that way its got fords name on it, not some off brand at autozone.
Old Jun 19, 2009 | 09:12 PM
2000AZ5.0GT's Avatar
2000AZ5.0GT
Autozone has the part, you have to search for it, but the part number is MT0887 I believe
Old Jun 20, 2009 | 12:14 AM
StockD15b's Avatar
StockD15b
i got mine today from autozone for 11bucks. bc ive kinda been having the same issue.long story..but got the switch and some freon. works just fine now.
Old Jun 20, 2009 | 01:11 AM
mrsinister2424
Good deal.
