another predator question
well i dont know if anybody can answer this but i had my cooling fans turned on w/my predator tuner i could always hear them winding down when the car was fully heated up and i turned it off i could hear the fans winding down but since i installed my 180* thermostat i dont hear them anymore so im guessing the fans will only turn on when the car was fully heated at 192* is there a way i can set the fans for 180* i dunno if this does me much good to have them on but i guess every little bit helps thanks for any response
The predator allows you to adjust setpoints for your fan's on/off. You may not need the fans with the thermostat, because they are setup for stock thermostat temps. Check it out on the modify parameters screen.
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
