Jackscrew?
Old Jul 3, 2009 | 06:27 PM
Lajit's Avatar
Lajit
Default Jackscrew?
i cant seem to figure out how i am suppose to loosin this screw called a jackscrew. i can access it through the hole in the side of the block after i take out the side main cap bolts. however, there doesnt seem to be a tool i have that will work to loosen them. any ideas? this is a 97 sohc engine.
Old Jul 3, 2009 | 06:56 PM
97gold's Avatar
97gold
y do need to take it out and what r u doing. I never new there was a such thing as a jackscrew
Old Jul 3, 2009 | 07:05 PM
Lajit's Avatar
Lajit
getting the crank polished, im doing a full rebuild. i got them out. it took an allen wrench it just doesnt look like it does
Old Jul 3, 2009 | 07:09 PM
Lajit's Avatar
Lajit
ok now that the caps are off, the rear main plate that covers the back of the block wont come off the back of the crank??? i assume the rear main seal is holding it. how do i get this off?
Old Jul 3, 2009 | 07:32 PM
Chris98Gt's Avatar
Chris98Gt
You need the correct size allen socket. then just loosen it up its only like 14 ft.lbs. I just took an allen wrench that fit and cut the L off and stuck it in a socket that fit and loosend it. I think craftsman has a set of long allen sockets, but I didnt have the set so I made my own.
edit: didn't read the last post. The plate is just tight It's got like a seal retainer or something, it'll come off with some force.
Old Jul 4, 2009 | 10:29 AM
Lajit's Avatar
Lajit
thanks for the help, i tapped it off with a small hammer and a rag to protect it.
1999GT
34
May 27, 2009 10:22 PM
