P0340
Old Jul 21, 2009 | 08:54 PM
s7stang's Avatar
s7stang
Default P0340
?? Camshaft Position Sensor A - bank 1 Circuit Malfunction ??
Ok, stang runs strong. Check Engine light came on so I checked the code and p0340 came up. Anyone have an idea where to start this repair?
Old Jul 21, 2009 | 09:07 PM
99mustanggt's Avatar
99mustanggt
Could be the sensor itself, the wiring or connector or the pcm.Try checking the connector and wires to make sure there are no breaks in the wire.If possible try ohming the wires to make sure they have continuity.If your capable you can test the sensor by finding the signal wire and using an analog multimeter, see if the signal is ocsillating between 0 and 5v while cranked.
Old Jul 22, 2009 | 12:11 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Check the alternator output. Have the Alt tested. Its common for people to replace the sensor and still have the code come back. Culprit is usually a bad diode or something throwing off RF signals from the voltage reg.
Old Jul 22, 2009 | 11:28 AM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
I second the Alternator RF signal causing the code.
Carcrazycorey1
May 15, 2013 09:52 PM
Stealthrida
May 3, 2010 08:53 PM
jaxbelleil
Oct 1, 2009 03:23 PM
cheftjpeck
Apr 4, 2008 02:06 PM
cheftjpeck
Aug 21, 2007 11:18 PM
