Engine misses at low RPMs
Old Jul 5, 2005 | 02:02 PM
polofool's Avatar
polofool
Default Engine misses at low RPMs
my 96 mustang GT misses out at low RPMs, I've changed the plug wires 5 times and this fixes the problem for about 1 month then it slowly returns. I have an aftermarket H-pipe and my O2 sensors are causing my check engine light to stay on. Is there any way this could be tied to my problem? My plugs look fine, anyone have any suggestions!!!!!
Everything else is stock on the car except for a K&N air filter
Old Jul 5, 2005 | 02:11 PM
BicketyBam's Avatar
BicketyBam
Default RE: Engine misses at low RPMs
I assume you removed your cats, correct? Get some MIL's or a prgrammer to get rid of the H-pipe caused check engine light. Then if you get a check engine light you will know that it's for something else. You can also get the codes pulled to see what is showing up (besides the midpipe caused code.) In fact, that's what I would do. When I had a misfire problem, the codes tell you which cylnder is missing.
Old Jul 5, 2005 | 02:16 PM
polofool's Avatar
polofool
Thanks, I have had the codes ran and it just says there is an O2 sensor problem, I'm actually about to buy the device to fix that. I thought maybe I needed a new set of coil packs.
Old Jul 5, 2005 | 02:37 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
Before you buy new coil on plugs.. flip flop them around and see if that particular coil. If not then you will be wasting your money.
Old Jul 5, 2005 | 02:50 PM
BicketyBam's Avatar
BicketyBam
ORIGINAL: polofool
If your car is truly misfiring, then it will throw a code. At least mine did.
ShaneB26154
35
Mar 4, 2021 04:05 AM
msavoia23
12
Jul 7, 2018 12:08 PM
Spiral534
Oct 6, 2015 04:31 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
Philhampton1
Aug 21, 2015 12:04 PM
