another predator question
Old Jul 8, 2005 | 12:45 PM
04GTMustangRob's Avatar
04GTMustangRob
Default another predator question
If I were to put the factory performance tune into my computer, what it the advance on the timing from the predator.
Anybody. I read the manual and it's not telling me.
thanks.
Old Jul 8, 2005 | 06:14 PM
Fat Nick's Avatar
Fat Nick
I ♥ Acer
Default RE: another predator question
What do you mean Rob. If you go back to a basic Diablo tune with no custom parameters and just set up the timing? If you go back to basic Diablo tune w/no customs but go in and change timing it will add to it what it already does with the basic Diablo tune.
And if you go back to stock tune (no predator at all) then everything will be the way it was the last time before you installed it.
Old Jul 8, 2005 | 07:28 PM
SilverGTV8's Avatar
SilverGTV8
The predator tune bumps timing 10degrees over the stock 10degrees, giving a total of 20degrees, and a max value of 22 degrees with adjustment.
Old Jul 8, 2005 | 10:35 PM
66_mustang_04's Avatar
66_mustang_04
ORIGINAL: SilverGTV8
no true, predator only goes to 2 degrees advance and 6 degrees retard
Old Jul 9, 2005 | 01:40 AM
SilverGTV8's Avatar
SilverGTV8
Yes true.[>:]
Take a reading before the tune is installed, 10degrees stock timing.
Take a reading after the tune is installed, 20 degrees timing.
With the 10% adjustment gives you another 2 degrees.
Total timing predator added 12degrees, this is why some go with a timing adjuster which allows over 14degrees, not just the 12.
Total timing in the motor 22degrees.
You just can't fully take away the predators inital timing, you can only retard it 6 degrees as you said.
ORIGINAL: 66_mustang_04
Old Jul 9, 2005 | 01:52 AM
maddash's Avatar
maddash
Yes true.
not true read the post on the running rich. if you bump timing 10 degrees from stock you want make far on pump gas before you blow a hole in a piston
Old Jul 9, 2005 | 01:54 AM
maddash's Avatar
maddash
I'm talking base timing maybe your not sorry
Old Jul 9, 2005 | 02:03 AM
SilverGTV8's Avatar
SilverGTV8
I am talking base timing. Stock timing is 10 at idle and on my car now is 22-23 at idle.
Tip in on the throttle and climbs to almost 40 at times and can hang around 30 until high idle kick down.
You certainly won't get far on 87 with advance timing, but with 91+ you need to listen for pinging with advnaced timing. I don't know why they didn't just install knock sensors on our motors[:@].
Old Jul 9, 2005 | 02:14 AM
maddash's Avatar
maddash
one of our dataloggers is screwed
Old Jul 9, 2005 | 02:29 AM
maddash's Avatar
maddash
just went and did datalogging @ idle
pred=18-20
factory=16-18
