rear end diff????
Old Sep 8, 2009 | 01:46 PM
01famousbullitt's Avatar
01famousbullitt
Default rear end diff????
well my differential started leaking yesterday, and imjust curious if anyone can give or find me some instructions to do this? im in germany and they dont really work on them and the ones that do cost a rediculious amount so im gonna do it myself..any help i would much appreciate!! thanks
Old Sep 8, 2009 | 02:16 PM
socalwrench's Avatar
socalwrench
If you're talking about the rear cover, it's simply bolted in place. Be sure a drain pan is under it as all the gear oil will come out. Replace the gasket (some guys use RTV also) and reinstall the cover. Fill the diff. with the CORRECT fluid up to the fill plug hole, and tighten the plug.
Old Sep 8, 2009 | 02:35 PM
01famousbullitt
thanks a bunch man, but one more quick ? how do i fill it back up....is there a plug at the top?i know i use a pump to put it in im just curious. dumb question i know but i dont wonna **** it up cause it has to go threw inspectiona and theyre **** on that type of stuff! thanks a bunch
Old Sep 8, 2009 | 02:47 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
The plug is on the upper, front, left of the differential housing.
You will also need to add 4oz. of friction modifier, unless you use a synthetic gear oil that does not need it. The FM makes the oils "slipperier" and is needed to keep the traction lock clutches from binding up in turns.
Old Sep 8, 2009 | 03:23 PM
lizzyfan's Avatar
lizzyfan
Underboss
Could be you pinion seal
Old Sep 9, 2009 | 12:06 PM
01famousbullitt
thanks a bunch guys!!! you guys are awsome
Old Sep 10, 2009 | 01:32 PM
socalwrench
A pinion seal leak is whole different repair, and much more difficult. I was hoping that he was referring to the cover.
Old Sep 10, 2009 | 02:03 PM
stangladesh's Avatar
stangladesh
Make sure you don't top it off. check bullittarchive.com. it has a step by step instructional with pictures. But it is simple to do. the site also has several other very informative how tos. some of which are not on this site. i actually did this about two months ago.
Old Sep 10, 2009 | 02:09 PM
stangladesh
by the way use royal purple. it has the friction modifier already in it.
Old Sep 10, 2009 | 11:04 PM
ShadyNinja's Avatar
ShadyNinja
they probably don't have it over there
mtgldr
Feb 3, 2024 09:00 PM
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
fastbackford351
Sep 12, 2015 09:42 AM
Dragonus18
Sep 9, 2015 01:21 AM
