aod question
Old Jul 11, 2005 | 12:34 AM
maddash's Avatar
maddash
Default aod question
how could i get my auto to shift from overdrive to second @70-80 mph without doing it manually. It is really irritating that it want and I'm thinking of driving the damn thing off a cliff.
Old Jul 11, 2005 | 12:43 AM
maddash's Avatar
maddash
Default RE: aod question
oh and dont tell me to buy a stick until after i post to tell you guys i drove it off a cliff. Sometimes I get a 20oz coke bottle in the cup holder and write Steeda on it and pretend i have a manual but that getting boring
Old Jul 11, 2005 | 01:00 AM
blueangelfightr's Avatar
blueangelfightr
Ummm, maybe turn your overdrive off? You can do that by pressing a tiny button at the bottom of the shifter head. You can tell it's off, because there will be a green light that comes up on your panel that glows green and says "OD off".
Old Jul 11, 2005 | 01:01 AM
02StanGT's Avatar
02StanGT
The Predator tuner allows for adjustments to shift setpoints such as rpms and shift firmness. Maybe someone with an auto and predator can confirm this.
Old Jul 11, 2005 | 01:11 AM
maddash's Avatar
maddash
I know that I'm stupid but not that stupid.If I turn off o/d that puts it into 3rd if I go wot at that speed it wont kick down to 2nd.
Old Jul 12, 2005 | 10:45 AM
DIVER8374's Avatar
DIVER8374
The reason that it does not kick down to 2ND gear is because the computer is set up for gas milage and not performance. Look at my mod list, if you want it to kick down to 2nd gear at that speed you have to do it manually!! I have used the predator to adjust my shift pressure and shift points, I suppose that if you want to you can adjust it so that it will shift to 2nd at thoes speeds, but I am not sure. I rarely need it to drop into 2nd at thoes speeds on the highway, and when I want it to I just move it there myself!!
Old Jul 12, 2005 | 11:30 AM
98UAGT's Avatar
98UAGT
There is no way around it except doing it manually. It shifts out of 2nd at 85 mph and 5500 RPM, so at 70-80 it would only be there for a split second with stock shift points. Just adjust your shift points/pressure/firmness with a handheld or shift it manually.
Old Jul 12, 2005 | 08:29 PM
Fat Nick's Avatar
Fat Nick
I ♥ Acer
Shift it manually downshifting, and say bye-bye tranny. If it's a 99-04 GT auto w/stock gears it will not go down that low at 70-80, you don't need it, you have more power at the rpms in 3 at that speed anyways.
Quit driving it like a ricer don't manually shift it ever. That is why it's automatic.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
