HID help
Old Oct 2, 2009 | 08:52 AM
99BlackPonyGT's Avatar
99BlackPonyGT
aka 'Negative Nancy'
Default HID help
when i turn my headlights on, sometimes the HIDs dont fire...sometimes one will fire and sometimes the other will etc... usually have to turn my lights on and off about 3-4 times to get both of them to fire and stay on
does this sound like a bad ballast or like a ground/power problem...my battery is pretty corroded, could that cause an issue like this? ive been meaning to clean it up but i havent gotten around to it
Old Oct 2, 2009 | 08:55 AM
NuclearMuscle523's Avatar
NuclearMuscle523
SCAM ALERT! This person is known around the internet for ripping people off. You've been warned.
sounds like bad signal voltage. might not be strong enough to get it "over that hill".
Old Oct 2, 2009 | 08:56 AM
josh662234's Avatar
josh662234
check your ground with a multimeter. If that is okay it is a sign of a ballast going bad. it has happened to me twice.
99BlackPonyGT
they will flash on for a second while the truck is cranking, then wont fire all the way.... do you think cleaning up the battery would fix it?
also, once theyre fired they dont have problems...once i get both to light, i can shut them off and turn them back on and they stay...also when i lock the truck they flash just like my normal headlights did
Old Oct 2, 2009 | 08:58 AM
99BlackPonyGT
if the ballast is going bad, wouldnt it cause issues all the time, not just when theyre cold? if i have them on, and shut them off, they never give me a problem coming back on...its just that initial start i have troubles with
Old Oct 2, 2009 | 10:05 AM
antiv6's Avatar
antiv6
are the the hids connected to the stock wiring harness or are they run through a relay connected to the battery? If they arent connected directly to the battery starting them may take to much power for the stock harness, relays are like 10-15 on ebay and get power strait from the battery through a proper wiring harness
Old Oct 2, 2009 | 10:06 AM
99BlackPonyGT
this.
Old Oct 2, 2009 | 04:03 PM
MU71L4710N's Avatar
MU71L4710N
your relays could be sticking. unplug the relays and plug the HID's directly into your stock wiring. run like that for a couple days and see how the headlights react. if they react the same - your ballasts are going bad. if they fire every time - your relays are sticking OR theres a loose wire with the relays.
Old Oct 3, 2009 | 11:40 AM
Retrosolutions's Avatar
Retrosolutions
Former Sponsor
remove your ground connections, clean the frame side of the contact area with sandpaper or wire brush and replace the grounds.
Diode Dynamics
28
May 26, 2022 12:02 PM
kawiguy827
Sep 22, 2015 10:52 AM
Mobiusone stang
Sep 7, 2015 08:46 PM
inyadreems
Aug 21, 2015 09:10 AM
stangmods.com
121
Mar 9, 2009 01:18 PM
