Please help, engine skipping, running out of ideas.
I'll continue to work on the COPs, pull them one by one, andI'll deffinately look for someone with another stang to see if I can more easily switch them out instead of buying ANOTHER set of plugs, cops, and switching it all out... that tends to be expensive on a college budget. I'll be sure to keep you guys posted.
UPDATE
I was testing wire by wire under the hood today, fuel injector and spark plug wires, to see if disconecting would result in any changes to find a faulty one.
I then discovered a colapsed vaccum hose that feeds FROM the passenger side engine bank INTO the block that the air intake is connected to (says 4.6) I think thats the throttle body? could be wrong on names, w/e. Does this make sense as to being the culprit for my loss of power? I'm obviously going to switch it as soon as I can get my hands on a new short piece of hose, but imput until then would be great, thanks guys.
Unless you have a programmer that disables your misfire monitor, if it is missing that badly you have to have some misfire codes that will tell you which cylinders. And if you do have a programmer, do yourself a favor and restore the stock tune so you can find out those codes.
That will help a ton in figuring out your miss!
Damn, I have this same problem. First I changed the fuel filter, no change, then took it for a complete diagnostic, and they found nothing. Didn't forget to charge me 80 bucks tho. Good luck fixing it, please let us know of any success. I don't really feel like spending any more money troubleshooting til I have a better idea of what it is.
100% the COP!!! do not go randomly replacing stuff and wasting your money. use ur squash. got water in the spark plug holes=bad coil on plug. if u don't have the money go to a do it urself junk yark and find a crown vic or some car with the 4.6 and grab a couple COP's from them. my dad had the same problem in his car (04gt) and it turned out to be a crack in the COP boot.
it better be the damn COPs, lol.
I just changed the spark plugs and fuel filter with no result... I'll be switching out the COPs as soon as I get a bit extra cash.
The cheapest I can find them is here: http://www.nationalfleetparts.com/DG...coil-pack.aspx for $34.
In the meantime, if anyone knows where to get Motorcraft COPs anywhere else for a cheaper price, let me know.
Thanx again.
Thanx again.
