The chance of pressed gears?
Old 10-25-2009, 09:16 AM
UmX
UmX's Avatar
Default The chance of pressed gears?
Wats the chances of having pressed on gears.. I wanna do cams but not sure if i will have the pressed or the easy ones.. I have a 01 Gt..
UmX is offline
Old 10-25-2009, 01:49 PM
masterofthepuppets99
masterofthepuppets99's Avatar
i believe it all depends on whether your engine is a romeo or a windsor.
masterofthepuppets99 is offline
Old 10-25-2009, 02:05 PM
Sxynerd
Sxynerd's Avatar
windsors are press on
Sxynerd is offline
Old 10-25-2009, 03:02 PM
JayC
JayC's Avatar
01 should have bolt-on gears.
JayC is offline
Old 10-25-2009, 09:34 PM
UmX
UmX's Avatar
oh how i could hope.. I wanna do hi-techs stage 2s, hoping for a nice sound, decent hp gain.. not sure wat kinda hp gain i will it.
http://hitechmotorsport.com/store/in...ducts_id=43789
almost worth it to buy the sprocket kit just incase..
also other main concern is the angle or degree i guess. Bc i have no idea how to do that.. Hell im going to try to install them with out knowing what to do.. By following a guide =/
UmX is offline
Old 10-25-2009, 10:00 PM
Sxynerd
Sxynerd's Avatar
are you deaf? Do you have a windsor or romeo??
judging by your car domain pictures, you have a Romeo; you have bolt on cam gears.
Sxynerd is offline
Old 10-25-2009, 10:38 PM
UmX
UmX's Avatar
Actually you cant be deaf when ur reading.
Obviously i dont know if i have a romeo or windsor i wouldnt have asked if i did..
And i went by wat jayc said..
UmX is offline
Old 10-25-2009, 10:50 PM
Sxynerd
Sxynerd's Avatar
You should have just asked what you had. That would have been simple enough. But you do have a romeo.
windsors are 99-Mid 01 so you had a possibility it was.
The cam covers and single bolt tensioner is what gives it a way.
happy camming
Sxynerd is offline
Old 10-25-2009, 11:09 PM
UmX
UmX's Avatar
happy camming
ugh.. Ill prob just cut them out.. to shave time..
Do u know if the hi-techs have to be set like degree or can u just put them in..
UmX is offline
Old 10-25-2009, 11:37 PM
Sxynerd
Sxynerd's Avatar
Factory cam gears are known for being up to 5* off. Does HiTech offer cam gears that are in spec with their cams? (I thought I remember reading they did.) Technically no, you don't have to degree your cams but I would consider it. Or at least get the their cam gears to.
You never know how far off the your cams will be if you try and install them straight up.
Sxynerd is offline
Quick Reply: The chance of pressed gears?
