has anyone ever
Old Jul 15, 2005 | 06:27 PM
silvergt's Avatar
silvergt
Default has anyone ever
have any of u guys every put a good tranny fluid in ur 5spd if so did help u out alot i know its not gonna make me faster but im hopin i can get in gears so much easier
Old Jul 15, 2005 | 06:37 PM
V8MustangPride's Avatar
V8MustangPride
Default RE: has anyone ever
Yeah in my 03 with the tremec 3650 i put Purple Royal in my tranny and it goes in reverse a lot easier, and grinding doesn't happen so bad like it use to, and a lot of times it doesn't grind at all.
Old Jul 15, 2005 | 06:41 PM
silvergt's Avatar
silvergt
thats exactly what mine does every time i try to go in reverse and i got some purple for it thanks for the input
Old Jul 15, 2005 | 07:27 PM
Deannostang's Avatar
Deannostang
Royal Purple anything is always a good choice! Change to Royal Purple oil and fluids and you car will love you for it. http://www.royalpurple.com/techa/whyrpa.html
Old Jul 15, 2005 | 07:42 PM
silvergt's Avatar
silvergt
ya im in the process of runnin royal purple everthing ive been using the engine oil for a while and now i got the tranny fluid to put in and some time ill get the rear end oil
Old Jul 15, 2005 | 11:53 PM
BraMas's Avatar
BraMas
A little trick I learned along time ago is put your car in 3rd before you go into reverse and it should not grind I was told it re-align's the gears so it won't grind. This has worked for me for 15yr I can't remember the last time I heard gears grind in reverse
ORIGINAL: silvergt
Old Jul 16, 2005 | 12:49 AM
Dan04COBRA's Avatar
Dan04COBRA
Actually, first gear will help.
Old Jul 16, 2005 | 11:22 AM
jishead's Avatar
jishead
I gotta try this stuff.
Old Jul 16, 2005 | 02:59 PM
kubball2005's Avatar
kubball2005
So how would I go about changing out my tranny fluid? I grind a lot into reverse too and I am due to change out my fluid. I know there's a plug under the tranny and do you just fill it through the top?
Old Jul 16, 2005 | 04:13 PM
The02GT's Avatar
The02GT
yes take the drain plug out along with the side fill plug (so it drains faster) and put the bottom plug back in after its done draining and fill with 4 1/2 - 5 qts (it will start to come out the fill plug when its full).
