Proportioning valve for brakes
Old Nov 3, 2009 | 08:53 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Default Proportioning valve for brakes
I went out to AX event over this past weekend and really found the bias a bit annoying. With my suspension set-up, I know it is possible to use my rear brakes to a better advantage.
I have done a bit of reasearch and peeked at the MMBPV-1 and see it is listed for a '79~'93.
Any input on those who have done this and what are your thoughts?
Jazzer... doin' the brake dance!
Old Nov 3, 2009 | 11:35 AM
H0SS302's Avatar
H0SS302
I would just call MM and ask em. I know the Baer makes one for our models becuase AZ2000GT has one IIRC. The bias is annoying as all hell tho. I havnt noticed it as much since I got better brakes tho.
Old Nov 3, 2009 | 12:55 PM
Brute03's Avatar
Brute03
i've really noticed it since i got the cobra brakes, seems like the rears don't much at all compared to other cars i've had
Old Nov 3, 2009 | 01:06 PM
hpwrestler220's Avatar
hpwrestler220
Hoss is right, 2000AZ has some kind of braking proportional valve in his car. PM him
Old Nov 3, 2009 | 01:52 PM
4.698GT's Avatar
4.698GT
Can someone explain exactly what this feeling is? Would something like this be different since I put a cobra rear in basically for the brakes.(best 150 I spent I think)
Old Nov 3, 2009 | 01:54 PM
Jazzer The Cat
Retired Moderator
Thanks, pepes... will do (but not 'til after my back is better. I threw it out when I served that Tabby )
Jazzer
Old Nov 3, 2009 | 01:55 PM
jmac72187's Avatar
jmac72187
corner carver
What about the bias is that annoying?
Old Nov 3, 2009 | 02:11 PM
H0SS302's Avatar
H0SS302
My car always felt like it was to light in the front. I dont know if it was just a faulty front caliper/pad but it just didnt feel right. Now that I have better fronts its where it is nice n heavy up front, probobly 70/30 I would guess?
Old Nov 3, 2009 | 02:12 PM
Jazzer The Cat
Retired Moderator
My braking would be more efficient with more rear brake applied
I am running R comps, Griggs SLA and tube "K" with torque arm. I have much less brake dive than stock, so am sure I can run additional rear brake. I am going to have my g/f make some vids this weekend on amount of brake dive and if the rears will lock at all. I will do some experimenting with "E" brake to see if I have any improvement.
Jazzer
Old Nov 3, 2009 | 02:27 PM
jmac72187's Avatar
jmac72187
corner carver
Maybe I am just use to the Cobra R kit.
Jazzer
That is what I figured. I am still on a mostly stock suspension in terms of actual design. Still the 4 link and modified MacPherson.
