Engine Shaking
Old Nov 20, 2009 | 12:47 PM
98redstang's Avatar
98redstang
Default Engine Shaking
I have a problem here. I have no idea what it is. Over like 65 mph if i let off the gas i get and shaking. Its not the tranny or anything. It has to be the motor because it also happens if i slowly bring the rpms up in neutral and once they get to around 3k i get the same shaking. It doesnt happen below like 60 or below 3k in neutral. ANy ideas?
Old Nov 20, 2009 | 12:56 PM
Frostbitten's Avatar
Frostbitten
well its either a motor mount or the engine isnt running right
Old Nov 20, 2009 | 01:01 PM
98redstang's Avatar
98redstang
I was thinking motor mounts. I had new ones put in when he did the motor so maybe they have to be retightened.
Old Nov 20, 2009 | 02:07 PM
Tim99GT's Avatar
Tim99GT
It could be a whole number of things....
I take it this is a fresh build? timing? i see your running 24# injectors and making - 290/320... do you have a BAP???
Can you post a vid of it? maybe you are having really bad detonation from the 87/89 octane...?
Like i said, it could be many things....
Old Nov 20, 2009 | 02:34 PM
98redstang's Avatar
98redstang
well eliminate the motor mounts its not that. the build is almost a year old the timing wasnt touched when it was tuned. I always run mid grade fuel which i believe is either 89 or 91 and whats a BAP?
Old Nov 20, 2009 | 02:55 PM
Tim99GT's Avatar
Tim99GT
boost a pump.
Increases the pumps voltage and in turn increases the amount of fuel the pump can pump.
Old Nov 20, 2009 | 03:08 PM
BraMas's Avatar
BraMas
Your drive shaft could be unbalanced. Has it been off recently?
Old Nov 20, 2009 | 05:13 PM
98redstang's Avatar
98redstang
I thought of that but like i said it happens just sitting there if i bring the rpms up to 3k. And as for the bap are you saying i need one? Or if i had one that could be the problem?
Old Nov 21, 2009 | 03:19 PM
98redstang's Avatar
98redstang
Anyone else wanna take a crack at it?
Old Nov 21, 2009 | 03:59 PM
stangalator's Avatar
stangalator
when does the stock fuel pump max out? However if this is happening around 3k i dont think you have a fuel shortage. Does it continue to happen above this rpm as well? maybe something with your harmonic balancer?
