nitrous and high compression???!!???
Old 07-18-2005, 12:52 AM
thasalvoo
thasalvoo's Avatar
Default nitrous and high compression???!!???
i was thinking of getting a nitrous kit from zex... what do u guys think of running nitrous on a high compression motor? my mods are in my sig.. i was looking either 50shot or maybe 100 if i can get away with it. any suggestions would be appreciated
thanx again
thasalvoo is offline
Old 07-18-2005, 01:10 AM
code3GT
Mustang Nazi
code3GT's Avatar
Default RE: nitrous and high compression???!!???
What kind of compression are you running? Nitrous likes compression.
code3GT is offline
Old 07-18-2005, 01:19 AM
thasalvoo
thasalvoo's Avatar
10:9:1
Old 07-18-2005, 02:01 AM
jdaniel
I ♥ Acer
jdaniel's Avatar
UMM... Yeah, you will do good. LOL
jdaniel is offline
Old 07-18-2005, 03:14 AM
thasalvoo
thasalvoo's Avatar
what do u mean do good?
Old 07-18-2005, 03:46 AM
num1son80
num1son80's Avatar
100 shot is easily safe just get a dyno tune since ure heads and cam eat up some extra flowing air...
K
num1son80 is offline
Old 07-18-2005, 11:49 AM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
You will be fine as long as the tune is good and run at least 100 octaine fuel when you are spraying.
JD1969 is offline
Old 07-18-2005, 03:50 PM
thasalvoo
thasalvoo's Avatar
so everytime i want to spray i have to run 100 octane fuel...???
Old 07-18-2005, 04:10 PM
thasalvoo
thasalvoo's Avatar
10:1:1 is the compression ... its mach 1 pistons ..
Old 07-18-2005, 04:15 PM
JD1969
JD1969's Avatar
Ahh see now before you said you had 10.9. You really need to figure out the actual copression ratio, not just what the pistons are, things like chamber volume, valve depth all make a differance.
JD1969 is offline
Quick Reply: nitrous and high compression???!!???
