shift kit
in my quest for infinate knowlege, i pose thee question......
what exactly is a shift kit? I could never understand that if an automatic tranny's job is to shift the gears,
then why would it "need" a shift kit?
how much do they cost and where can they be found?
thanx!
thanx!
What a "shift-kit" does is make the shifts firmer and faster by increaseing the line pressure and modify the way the stock one shifts. A shift kit will actually increase the life of your trans because the faster/firmer the car shifts the les slippage and therfore the less wear and tear on your trans. If you have a auto I highly suggest that you get one, along with a trans cooler!!! You will really love the way your car shifts with a shift kit in it!!!
Trans-go ( transgo.com ) makes them (the same one that I have) and the shift kit was $135 shipped to my door. I had mine installed by a transmission shop because 1) I did not want to mess it up 2) I do not have a place to do the work myself.
i was wonderin, about that installation price too. PM me or somethin man, im lookin in to the same shift kit, but i need to know how much to install bc i dont wanna get one if it is so much money to install :-)
thanks
thanks
ORIGINAL: ghoste
get a predator, you can increase pressure from there plus alot other options...
This will work to help out your shifts, BUT it is nothing compared to the shift kit. After a week or two of haveing the shif kit in my car I went in and increased the line pressure a little bit more and now the car kicks really good going into gears!!!!
