PCM memory problem
Old Jan 19, 2010 | 08:00 PM
Dr.Stock's Avatar
Dr.Stock
Default PCM memory problem
I have a 2000 GT 4.6 with Automatic trans. When it wouldn't pass inspection, the shop told me that the computer was losing its memory everytime the key is turned off. They said that either the continuous 12v wire to the computer is bad or the internal memory of the pcm is bad. I have confirmed that the computer has cont. 12v but want to know if anyone else has had this problem before I purchase another pcm. Also, the fuel economy around town is very bad. I assume that if the memory is bad that the computer has to re-learn every time the car is restarted. Also, does anyone have a recommendation where to buy another computer other that Ford?
Old Jan 20, 2010 | 07:51 AM
DR.DIESEL's Avatar
DR.DIESEL
npc automotive will sell you a recon pcm with the info already loaded on the pcm,1-866-326-4227,comes with a 1 year warranty
Old Jan 20, 2010 | 03:28 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Did you check the 5A fuse in position 21, under the dash?
Old Jan 20, 2010 | 04:58 PM
Dr.Stock's Avatar
Dr.Stock
Ya, the fuse is good.
Old Jan 20, 2010 | 04:59 PM
Dr.Stock's Avatar
Dr.Stock
Thanks for the info. Do you know how much it should cost?
Old Jan 21, 2010 | 07:58 AM
DR.DIESEL's Avatar
DR.DIESEL
JUST GIVE THEM A CALL AND THEY WILL GIVE YOU A QUOTE OVER THE PHONE
Old Jan 21, 2010 | 08:26 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
If you haven't already dome so, I would also check for +12V continuous at pin 55 of the PCM, just to be sure it's not a wiring issue, before springing for a new box...
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
