2v gt Heads
Old Mar 6, 2010 | 09:24 PM
chrisgtr's Avatar
chrisgtr
Default 2v gt Heads
this is what the heads on my 99 GT look like. to the best of my knowlege im the first to pull the heads on my car and im curious as to why my "stock?" heads look like this:
http://blogs.mustangandfords.com/652...ads/index.html
instead of this:
http://www.speedconcepts.net/product...qq52icplvm0803
(in the chiltons manual this is what they are supposed to look like)- mine doesnt have the "cap clusters".
Old Mar 6, 2010 | 09:47 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
romeo vs. windsor motors..
/thread
Old Mar 6, 2010 | 10:21 PM
chrisgtr's Avatar
chrisgtr
/thread
so because mine is a windsor thats why it doesnt look like that??
Old Mar 6, 2010 | 10:34 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Correct...
I dont remember which were which but the cam caps are different on each style
Old Mar 7, 2010 | 12:10 AM
chrisgtr's Avatar
chrisgtr
so as far as timing the heads... since i marked TDC on them, can i line them up, put the chain on, then tighten the caps down?? cause with the caps already tightened, it makes it hard to line up the TDC marks due to valve spring compression.
Old Mar 7, 2010 | 01:57 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
(I'm beyond drunk so please excuse me if I am wrong)
I believe when you set timing on these motors you remove the followers with a special tool. You set the timing where it needs to be then insert the followers back.
Old Mar 7, 2010 | 05:35 AM
ESABATM's Avatar
ESABATM
If you are using the caps to pull down the cam on the rockers is bad. If you break one of those guys the head is junk.
Old Mar 7, 2010 | 08:07 AM
Chris98Gt's Avatar
Chris98Gt
Yea, the windsor heads have individual cam caps and romeos have the "all in one" setup. just pop the followers out, time the cams and reinstall the followers.
Old Mar 8, 2010 | 01:15 AM
chrisgtr's Avatar
chrisgtr
i dont understand what you mean by "pop the followers out". i think i do im just not sure.
Old Mar 8, 2010 | 10:44 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
you have to remove these
THEN set the timing, and (using a special tool you can purchase that looks like THIS)
depress the valve springs and valves and re-install the followers. You should only have to remove the ones that are actually making contact with the lobes. Not all of them on each side will have to come out
