cams
alright. i was thinking it could be a timeing problem. does the computer need to be adjusted for the new cams. its trickflow cams. i did a measure of depth from valve to piston and i couldn't get comp cams
do NOT run your cams w/out a tune... that is just stupid.
I had my cams un-tuned from the time that a local shop installed them, then drove to the guy that was gonna tune it... The car sounded like **** and I was sure I was doing damage to the engine.... Ticked like CRAZY
Dont do it. Its not good for ur car.
A tune is an absolute MUST with new cams. You might get away without a tune on Stage 1s but you're losing out on most of the gains you're looking for. Also, did you properly degree the cams or did you use the Ford method? The Ford method can be off by as much as 4 degrees.
junior04
Sep 28, 2015 10:53 AM
