Cam Question
Old Apr 25, 2010 | 09:51 PM
HasABetterSN's Avatar
HasABetterSN
Default Cam Question
Hey guys - if you get new cams, is it necessary to get new PI heads too?
Old Apr 26, 2010 | 08:53 AM
K Z's Avatar
K Z
99+ then no. They already have the PI heads, but your cam has to be very mild as not to damage any valves and stuff.
Old Apr 26, 2010 | 09:35 AM
HasABetterSN
Perfect since I've got a 2002. thanks
Old Apr 26, 2010 | 10:06 AM
GTRACER88's Avatar
GTRACER88
Not true...
Old Apr 26, 2010 | 04:06 PM
HasABetterSN
Originally Posted by GTRACER88
Not true...
how so?
Old Apr 26, 2010 | 06:21 PM
K Z's Avatar
K Z
Yea I would like 2 hear more on this as well. I thought without having some grinding done stage 2's are around the max on stock PI heads
Old Apr 26, 2010 | 06:25 PM
mrtstang's Avatar
mrtstang
You guys are correct. Stock PI heads don't offer a lot of clearance. You are definitely limited to certain specs.
Old Apr 26, 2010 | 06:47 PM
HasABetterSN
so going with what youre saying, I should be fine using stage I cams with stock PI heads right?
Old Apr 26, 2010 | 07:22 PM
K Z's Avatar
K Z
You could do some stage 2's, so if all you want is stage 1's you will be fine.
mrtstang's Avatar
mrtstang
Well not necessarily. It depends on the specs, and weather you degree them or not. One company's stage 1 might be more like another company's 2. The whole "stage" business need to be thrown away IMO. What cams are you looking at? In general most stage 1 type cams will drop in as is and be okay, but again it depends on a few things.
