2002 GT
After reading some threads I got to thinking bout some things. People say to find out whether you have a Romeo or Windsor look at your VIN the 8th number. If its an X you have an 8 bolt windsor, well I have an x in the VIN and my car has a six bolt crank. Also, I've heard people say that 02 and up should have 21# injectors (pink), but mine has 19# injectors (yellow). Can someone clue me in why that my be? Thanks
It doesn't matter, I was just wondering. Thought it was kind of odd people say the x in the vin means you have an 8 bolt windsor, and when I swapped engines turns out it was a 6 bolt. Kind of like JD's thread that said don't post if you don't know ****.
ORIGINAL: jdaniel
You should have 21 lb injectors. You wont have the Windsor block though. My GT was built in march of '02 and I had the six bolt crank also.
... and according to SCT:
all GT's have 19's. The pink injectors are 19# injectors. I have no idea where this 21.5# stuff started from but it's WRONG. Now, the 3.8L's do use a 21# injector since 1999 when they introduced the split port motor.
I just checked the EEC calibration for a 00 and an 03 and they both are setup for 19# injectors.
