Slop is Steering...?
Old May 18, 2010 | 06:00 PM
GreenY2KGT's Avatar
GreenY2KGT
Default Slop is Steering...?
My steering has a little bit of play in it and I would like to fix it? I was hoping that it is gonna be the steering shaft as it would probally be the cheapest thing to replace. Any suggestions? Brad
Old May 18, 2010 | 09:11 PM
945LSTANG's Avatar
945LSTANG
how much is "a little bit of play?" some play in the steering wheel is normal.
Old May 19, 2010 | 05:33 AM
uberstang1's Avatar
uberstang1
Chupacabra
It could be a few things, the steering shaft, inner tie rods, tie rod ends, the rack.... Did u jack up the front and shake down the wheels to check for play?
Old May 19, 2010 | 06:47 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Not for me
I am with Uber here... do some poking around for worn parts/bushings.
Jazzer... poppin' off agin'
Old May 2, 2011 | 12:23 AM
cisurfer's Avatar
cisurfer
i shook my wheels for play and there is, what could it be
Old May 2, 2011 | 05:18 AM
uberstang1's Avatar
uberstang1
Chupacabra
Worn rubber rag join on factory steering shaft, the heat thrown off from long tubes often kills them fast due to the fact its almost right next to them.
Old May 2, 2011 | 09:17 AM
cisurfer's Avatar
cisurfer
its not the shaft, i just put a new one in and when i shake the steering wheel the rack where it connects to the shaft moves, when i shake the drivers side wheel i hear a banging too, havent tried the passenger side yet
Old May 2, 2011 | 10:47 AM
BraMas's Avatar
BraMas
Wheel bearings?
Probably should have started your own thread now people are going to answer your ?'s and the OP's ?'s on a dead thread and it is going to get confusing
Old May 2, 2011 | 12:40 PM
cisurfer's Avatar
cisurfer
i did but only uber responded lol
Old May 3, 2011 | 05:13 AM
uberstang1's Avatar
uberstang1
Chupacabra
Like do you mean the whole rack moves on the k-frame? Inner tie rod?
