Fuel setup
Old Jun 8, 2010 | 07:43 AM
98redstang's Avatar
98redstang
Default Fuel setup
Im in the process of a supercharged motor build. My question is what do i need in terms of an upgraded fuel pump/accesories? I know 98s are a pita with the way the fuel setup is. Im looking to make around 450 500rwhp. Any suggestions on what i should go with?
Old Jun 8, 2010 | 10:44 AM
code3GT's Avatar
code3GT
Mustang Nazi
Depends on how much $$ ya wanna spend. I'm not too up on the SN95's, is the fuel system basically the same as the new edges?
Old Jun 8, 2010 | 10:58 AM
Armydad's Avatar
Armydad
Hey,
I researched this as well, I am doing a V1 kit,but I only want 350-380 rwhp. From what I've found after about 400HP the gas tank baffling becomes an issue and either a custom tank, or a cobra set up is needed. At 500hp you will def need to modify the tank and prolly dual pumps. Try this link, www.glennsperformance.com. They have a bunch of setups ready to go. Also search for fuel tank upgrade in the search function. Good luck
Old Jun 8, 2010 | 11:10 AM
zero2005's Avatar
zero2005
not sure about the 98's stock setup but, depending on injectors/tune, you might be able to get away with a 255lb SVT focus pump and a Kenne bell boost-a-pump. i know of a couple turbo cars runnin like this pushin high 400's. of corse, i've also heard if you run it like this, dont go below 1/4 tank of gas and expect to go WOT without something happening.
but if you feel like you wanna go more than 450-500, get a sumped tank or cobra tank w/ dual pumps.
Old Jun 8, 2010 | 03:05 PM
lizzyfan's Avatar
lizzyfan
Underboss
Get a 97 tank and drop in a 255lph
Wire the pump to a constant 12v
I think I went over this with you before
Check this out
https://mustangforums.com/forum/4-6l...l-systems.html
Old Jun 8, 2010 | 03:06 PM
lizzyfan's Avatar
lizzyfan
Underboss
Not gonna work on return style setup
Old Jun 8, 2010 | 07:17 PM
Mustang_NTriangle's Avatar
Mustang_NTriangle
if your goal is 450-just under 500 rwhp you don't need dual cobra pumps. I got myself Focus fuel pump, Kenne Bell BAP, blower cams, in terms of a MAF I pegged my Lightning meter around 450 rwhp or slightly under. I recommend Pro 92 Meter with andersen power pipe both pieces are 4 inches.
Old Jun 8, 2010 | 10:16 PM
98redstang's Avatar
98redstang
Check this out
yes we did lol. How do i wire it to a constant 12v? I found a sumped tank from a 97 gt on craigs for 150
Old Jun 9, 2010 | 07:33 AM
98redstang's Avatar
98redstang
is this what i need as far as a tank? http://cnj.craigslist.org/pts/1755918887.html
Old Jun 9, 2010 | 08:45 PM
lizzyfan's Avatar
lizzyfan
Underboss
If you have a tune you can use the tunes software to send a constant 12v
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
fastbackford351
Oct 1, 2015 12:24 PM
guitarman376
Sep 30, 2015 05:54 PM
mrappe
Sep 26, 2015 10:16 AM
