What is this?
Old Aug 10, 2005 | 02:48 PM
iwantone's Avatar
iwantone
Default What is this?
hey guys, i was wondering if anyone knew what this thing was under my dash. it has wires that run up behind the dash too.
[IMG]local://upfiles/11030/22949FE015654177A20A5A96F5BA5EE2.jpg[/IMG]
Old Aug 10, 2005 | 03:06 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
Default RE: What is this?
I think I have one of those too. it's an engine cutoff switch that uses a chip as the key. If you paid the extra money when you bought it, they put a chip that is removable in there. If you didn't pay the money, the chip is permanent (i.e. no plastic handle to remove the chip with).
Old Aug 10, 2005 | 04:15 PM
iwantone's Avatar
iwantone
i don't think it is a factory install because if you look where the screw is the dash panel cracked where someone did a sucky install. also it is a 97 gt vert, guess i should have said what it was earlier.
Old Aug 10, 2005 | 04:17 PM
StickShifty's Avatar
StickShifty
it looks like a plug for one of thoes aftermarket plug n play tuners.
redass02gt's Avatar
redass02gt
EXTREME Moderation
mine was a dealer install, not factory. I think the dealers use those for their cars so they don't get jacked and then give you the option to buy it.
Old Aug 10, 2005 | 04:19 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
is it on the drivers or passenger side? if it's on the passenger side then it is not what I have. Mine is directly under the steering wheel. Also, it looks like something is already in the port.
Old Aug 10, 2005 | 04:44 PM
iwantone's Avatar
iwantone
it is directly under the steering wheel.
i thought it was a tuner port at first but then i remembered that they use the diognostic port.
it just pisses me off that it cracked my dash whatever it is.
Old Aug 10, 2005 | 05:16 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
does it look like a little chip is already inside of the port? if so, it's probably what I thought it was.
Old Aug 10, 2005 | 07:32 PM
iwantone's Avatar
iwantone
i can't really tell
