Engine swap for 96 mustang gt
Old 10-24-2010, 03:39 PM
frarey17
frarey17's Avatar
Default Engine swap for 96 mustang gt
So during this upcoming winter i was thinking of looking for an engine to swap into my car. Now im not trying to buy a brand new engine but something i can probably find at a junk yard
frarey17 is offline
Old 10-24-2010, 05:12 PM
MU71L4710N
MU71L4710N's Avatar
mark VIII swap is pretty cheap and easy. you could try to find a 96-98 cobra engine if you want to spend a little more.
search for jc316 i think is his name he did the mark VIII swap and has a write up about it (his was a 96 or so too i think so the writeup should be identical for you)
MU71L4710N is offline
Old 10-25-2010, 09:42 AM
kugzgt
kugzgt's Avatar
is there something wrong with ur motor? consider a build
kugzgt is offline
Old 10-25-2010, 09:58 AM
PovertyPony
PovertyPony's Avatar
The good ole PI swap is something to consider as well. Most people swap the top end out, but the actual PI motor swaps pretty hassle free if you want a whole motor. Just swap the motor and go, the '96 computer system will run it.
PovertyPony is offline
Old 10-25-2010, 12:09 PM
98GTstang
98GTstang's Avatar
Yeah, i dropped a 03 GT motor in my mustang about a year ago. Has alot more power then the crappy non-pi motor. It all depends on how much you want to spend.
98GTstang is offline
Old 10-25-2010, 06:26 PM
frarey17
frarey17's Avatar
The only thing wrong with it is that it leaks and burns alot of oil. But on top of that i want something with a little more base power than 215hp. I went to the junk yard and saw alot of town cars explorers and i think a mark VIII. I just want to get a better engine than i have now that is worth going through the trouble of swapping
frarey17 is offline
Old 10-25-2010, 06:40 PM
JC316
JC316's Avatar
Hey, I am the guy that did the Mark VIII swap. You can check my guide in my signature. Now, I have done both a PI swap GT with a ton of bolt ons and the Mark VIII swap stock. The Mark VIII swapped GT was faster.
With the Mark VIII engine:
http://www.youtube.com/watch?v=V7J0tcDjlwY
With the PI Swap, it has gears, so 65MPH is 60MPH:
http://www.youtube.com/watch?v=KfdIK3QovvM
JC316 is offline
Old 10-26-2010, 05:45 AM
uberstang1
Chupacabra
uberstang1's Avatar
Be carefully getting a mark 8 motor from a pick a part junkyard as it can be very risky. 1. Make sure it wasnt a cash for clunker trade. Also if the car seems to have no collision damage and its sitting in a junkyard you have to realize there was probably a major drivetrain issue with the car that the owner decided was to expensive to fix and junked the vehicle.
uberstang1 is offline
Old 10-27-2010, 10:55 AM
4v Shane
4v Shane's Avatar
pop out the pistons bore it over
boom more cubes off the bat
and a forged bottom end to boot!
That way your core is already good to go and work your way up to ported heads/blower cams etc.
4v Shane is offline
Old 10-27-2010, 10:57 AM
4v Shane
4v Shane's Avatar
While on the topic I have enough parts to throw together about 3 4.6 4valves
4v Shane is offline
Quick Reply: Engine swap for 96 mustang gt
