HELP PLEASEEE!!
Old Nov 16, 2010 | 03:14 PM
misz_melanie's Avatar
misz_melanie
Default HELP PLEASEEE!!
HELP PLEASEEE!!
i just baught a 96 mustang only to find out the car was overheating_replaced the radiator ; head gasket && head_car doesn't overheat anymore so far but smells like burning oil. i think the other head gasket is bad also, baught a new head gasket and planning on replacing it - dual exhaust ;; __ on the driver side still blowing out smoke on the passanger side its clear ;; spitting out water occasionally? now when i turn on the car and its running && i turn on the heater _ the car dies out - replaced the battary - still dies when heat is turned on anybody got any suggestions?
thankss!
Old Nov 17, 2010 | 09:25 AM
Case's97GT's Avatar
Case's97GT
Wow... you have alot going on there
burning oil may just be residual from changing things. Does it leak? Coolant comes either from your water pump in the front or a head gasket.
As for your heater need more details, does the fan blow at all? the only thing creating heat is the heater core which just holds coolant so You may have an issue with the fan or a relay.
misz_melanie
Nov 21, 2010 05:04 PM
misz_melanie
Nov 16, 2010 03:02 PM
misz_melanie
Nov 16, 2010 02:58 PM
Str33tGunner28
Nov 1, 2006 10:46 PM
