FRONT TIRE HELP ASAP
Old Dec 19, 2010 | 01:26 PM
Junior13's Avatar
Junior13
Banned
Default FRONT TIRE HELP ASAP
Just wondering why this is happeneing and how i can fix it.
im running 255/45/18 in the front and 285/40/18 in the rear
people run bigger then this upfront all the time, i feel like the car is running the fenderwell on a full turn
why is this?
Old Dec 19, 2010 | 05:37 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
255/45-18 is 1.3" larger diameter than the stock tire (245/45-17), it will rub on tight turns.
The 285/40-18s are also of a larger diameter than stock--this will mess up the speedometer and reduce rear wheel torque delivered to the ground, it's nearly the same as having 3.08 gears in the rear end.
Why did you buy such big tires? 255/40-18 on the front, and 285/35-18s on the back, would be much closer to the OEM tire diameters...
Old Dec 19, 2010 | 07:46 PM
Junior13's Avatar
Junior13
Banned
im sry i have 285/35 in the rear but the front are 255/45/18 how come i see people running that with no problem
Old Dec 19, 2010 | 08:02 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Because they got lucky? It's not a common tire size for new-edge Mustangs--mostly because it's too damned big...
IDK, maybe with the stock "monster-truck" ride height it would work out OK???
Old Dec 21, 2010 | 01:55 PM
Junior13's Avatar
Junior13
Banned
any idea why my tc randomly turn on? is this related? or a coincidence. i just drive with it off but if its on it randomly activates
Old Dec 22, 2010 | 04:29 AM
mance01cobra's Avatar
mance01cobra
I used to have this prob when I had my GT but one day it just went away.... wish my ex-wife would do the same lol
Old Dec 22, 2010 | 07:13 AM
IRSmart's Avatar
IRSmart
because your tires you're running are different hights and it's pissing your car off. get the correct size tire for your car, (or more correct, as it is impossible to get a tire on an 18 inch rim that is 100% the same hight as a 17" rim, on these cars anyway). i don't understand why you would willingly put tires on your car that are BIGGER than what it came with. go monster trucking much?
Old Dec 22, 2010 | 07:24 AM
mance01cobra
do u happen to have spacers?
Old Dec 22, 2010 | 12:12 PM
Junior13's Avatar
Junior13
Banned
well i have3 285/35/18s on the rear, that size is correct. what size should i put on the front???
Old Dec 22, 2010 | 02:18 PM
IRSmart's Avatar
IRSmart
how wide are the rims?
