we have problems...
First time taking the car to the track today and wasn't happy at all. I have a 97 convertable thats mostly stock with flowmasters dumped, cai, 75mm bbk throttle body and c&l plenum.
First run I spun bad through first
2.7 60 ft
ll.08 1/8th at 65.03
1/4 17.16 at 80.404
I thought this was from the terrible start but figured from the mph that something was wrong.
second run.
2.4 60 ft
1/8th 10.4 at 66.03
1/4 16.44 at 82.23
I've changed the plugs, wires and oil. I need the change the air and fuel filter but still theres no way even with terrible driver error that the car should have ran that slow. It should have been trapping in at least the 90s right? I'm embarrassed to say but I got beat by a 4wd f150.
I should have at least been in the 14s
Any idea on why my car ran so slow or what I can do to help it out?
2.7 60 ft
1/4 17.16 at 80.404
second run.
2.4 60 ft
1/8th 10.4 at 66.03
1/4 16.44 at 82.23
There was a 98 running full exhaust and a zex 100 shot hitting mid to low 12s. Would those mods really make that huge of a difference?
I was about to do full exhaust but after this I was thinking the motor was running on its last leg or something, I was even considering selling it. Also because its a vert which means I have to have a cage for anything under 13.5
I was planning lts, and off road h. If thats not going to do much then I'll start saving for a pi swap or a supercharger. Another thing would be gears. I was told I had 3.73s when I bought the car but I don't think they are if I'm at 2000 rpms in 5th doing 70?
I know those 60s are bad but after my first run frying all of first then bogging second I wanted make sure I didn't do that again. I lowered the tire pressure for the second run and it did a little better but still bogged off the line.
I know gears are supposed to do a lot but I'm trying to determine the gears I have before spending money on gears that I might already have. I haven't gotten a chance to count drive shaft to tire rotation to make sure but judging by my rpms I have stock gearing. I know tuners make a difference but I thought exhaust and gears should come first. Also since my cars a 97 for some reason diablosport doesn't make a tuner for my car.
ouch...
non-PI GTs along with the stock 94-95s are just pigs. i ran a 15 hammering the gears. the extra weight of the vert isn't helping either.
