comp cams?!?
Old Apr 11, 2011 | 11:06 AM
timeformiller44's Avatar
timeformiller44
Default comp cams?!?
I have these http://www.americanmuscle.com/mustang-comp-cams-xe270ah.html and can't find how to time these to our motor. I don't think stock Ford timing is right seeing as its an interference motor and.these cams lift a lot higher. Any ideas????
Old Apr 11, 2011 | 11:35 AM
timeformiller44
Also looking to buy a 2004-2004 4.6 shortblock 6 bolt crank if anyone knows where I can get a used one
Old Apr 11, 2011 | 12:35 PM
zero2005's Avatar
zero2005
http://www.modularheadshop.com/Artic...stallation.htm
this cam install and timing. they have other articles cover other stuff as well.
Old Apr 11, 2011 | 12:41 PM
timeformiller44
Hopefully this works for after market cams
Old Apr 11, 2011 | 01:40 PM
zero2005's Avatar
zero2005
whoops my bad, thats basic install. here's the degree article:
http://www.modularheadshop.com/Artic...m%20degree.htm
Old Apr 11, 2011 | 01:54 PM
mrtstang's Avatar
mrtstang
+1 on MHS. They'll point you in the right direction.
Old Apr 11, 2011 | 02:35 PM
zero2005's Avatar
zero2005
used crank? what do you need a used crank for?
there's a couple of Mach 1 cranks on ebay for about 200$, if it came out of a manual car it should be forged.
Old Apr 11, 2011 | 03:26 PM
timeformiller44
No I need a whole short block
Old Apr 11, 2011 | 03:30 PM
mrtstang's Avatar
mrtstang
Are you throwing the cams in your current motor or the new short block?
Old Apr 11, 2011 | 04:10 PM
timeformiller44
A new shortblock if I can find one current one is junk I have no motor
