Trouble code P0303
Old Apr 15, 2011 | 02:11 PM
Mach1 Ketchum's Avatar
Mach1 Ketchum
Default Trouble code P0303
My scanner kicked the trouble code P0303 for a misfire on cylinder 3 and I'm going to replace it, but which cylinder is that? Driver side or Passenger side?
Old Apr 15, 2011 | 02:30 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Misfire codes do not automatically mean an ignition problem, in fact the PCM has no idea what caused the misfire.
Click here to see how the misfire monitor works;
Click here for what the shop manual says about P0303.
Cylinder 3 is 3rd from the front on the passenger side:
Old Apr 15, 2011 | 05:16 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
If you can physically feel a miss, its most likely a bad coil. Like cliffy said its not always the case, but I can almost assure you 100% that replacing the #3 coil and plug will fix the issue
Old Apr 16, 2011 | 06:35 PM
jtb727's Avatar
jtb727
Had the same code, swapped my plug and it fixed it.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
CS2007
Jun 25, 2019 09:45 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
