Transmission fluid question.
Old Apr 21, 2011 | 02:50 PM
SourDiesel78's Avatar
SourDiesel78
Default Transmission fluid question.
I have a 96 GT 4.6L, I am replacing the clutch this weekend and wanted to know if I should used the same transmission fluid that i remove, or replace with new and with what, ATF, Gear Oil, Etc. Please keep in mind the trans has 203k miles on it. Thanks for any feedback
Old Apr 21, 2011 | 04:35 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
ATF, you can download an Owner's Manual from Ford here...
Old Apr 21, 2011 | 04:43 PM
AsBaNy's Avatar
AsBaNy
hi
i think new fluid better it will be clean and better quality.....
regards
Old Apr 21, 2011 | 04:49 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Originally Posted by AsBaNy
hi
regards
I would never re-use any sort of fluid...
Old Apr 21, 2011 | 05:18 PM
cisurfer's Avatar
cisurfer
Use gm mercon. Not synthetic it's bad for the synchros
Old Apr 21, 2011 | 05:38 PM
Romer's Avatar
Romer
Where do you get this from? Tremec 3650 workshop manual says to use Ford Mercon or Mobil 1 atf synthetic?
Old Apr 21, 2011 | 05:49 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Your '99 has a T-45 transmission, not the 3650...
Old Apr 21, 2011 | 06:02 PM
96meangreengt's Avatar
96meangreengt
I used GM syncromesh in my 96 and it shifts smooth as butter.
Old Apr 21, 2011 | 06:18 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
FWIW/FYI--GM's Synchromesh is a synthetic/dino blend...
Old Apr 21, 2011 | 06:35 PM
Romer's Avatar
Romer
It used to. Now it has rebuilt 3650 extreme from American powertrain. The same company that told me that my 5th gear noise at 60 mph was caused by me using synthetic atf. When I asked Richard at American Powertrain a second time he recommended mobil 1 synthetic lol.
