super charger help
Old Apr 30, 2011 | 04:05 PM
tduzick's Avatar
tduzick
Default super charger help
I am looking to buy a centrifigul super charger for a stock 2002 mustang gt. What would need to be done in order for me to get the engine ready for a super charger? I also would like to know about the different types, and which is better and why? thank you
Old Apr 30, 2011 | 04:30 PM
Dave19525's Avatar
Dave19525
The stock engine will handle the supercharger just fine as long as you dont go over about 400 rwhp. You will need to upgrade your fuel pump and replace spark plugs, fuel injectors and MAF. You will also need a good tune. As far as which one is better, there are all kinds of opions on that. If you search this forum, it is loaded with info. Good luck with your build.
Old Apr 30, 2011 | 04:35 PM
tduzick's Avatar
tduzick
Thanks a lot man. I am looking at the vortech and procharger and I think im leaning more towards the vortech. What type of plugs injectors and such would be good for this?
Old Apr 30, 2011 | 06:38 PM
Hoppers04Gt's Avatar
Hoppers04Gt
Alot depends on how much you wanna spend. What is your ulimate goal for the car?
Old May 1, 2011 | 12:11 AM
tduzick's Avatar
tduzick
It is going to be a daily driver for a good 3-4 years while I'm in college. Then I am turning it into a weekend warrior/track car. I don't want anything crazy. So for now I was wondering if the set up to run the supercharger would hurt the car without the charger, or help it. If it helps it than I will run that until I save up money for the charger.
Old May 9, 2011 | 09:12 PM
Modular_Madness's Avatar
Modular_Madness
Banned
Buy an actual kit from vortech it comes with everything needed.
Old May 9, 2011 | 10:12 PM
Rockwell28's Avatar
Rockwell28
http://www.summitracing.com/parts/VOR-4FL218-130S/ blower kit
http://www.blueovalindustries.com/en...ts/en1200.html maf
http://www.summitracing.com/parts/ATM-10005/ gauge pod
http://prosportgauges.com/green-whit...ure-gauge.aspx
http://prosportgauges.com/green-whit...ost-gauge.aspx
Old May 10, 2011 | 05:04 AM
mrtstang's Avatar
mrtstang
Honestly, if you can afford it i would buy a Kenne Bell. The power band of a twin screw blower is much more fun than a centrifugal.
Old May 10, 2011 | 05:08 AM
uberstang1's Avatar
uberstang1
Chupacabra
Ehhh. Non-intercooled KB is just ehhhh. To much heat soak on a hot day.
Old May 10, 2011 | 07:11 AM
mrtstang's Avatar
mrtstang
Oh i would NEVER recommend a non intercooled twin secrew lol. I was referring to a intercooled setup if he could swing it.
