Correcting speedometer speed??
A few weeks ago I bought an 01 GT and on my way home I noticed that it had gears but I am not sure what is in there. My speedometer is off a good amount does anyone no if I can correct the speedometer with a factory FORD scan tool. I have an NGS scanner but can't figure out how to do it. In my 01 Explorer I can correct it through the GEM module but on my Mustang I can't.
This will fix your speedometer
http://www.americanmuscle.com/ford-s...tool-9410.html
Jack up the rear end of your car so both wheels are off the ground, put a mark on the drive shaft, put the car in neutral and rotate one of the wheels all the way around. How many times your drive shaft rotates during the wheel rotation tells you what gears you have in your rear end. If it rotates 3 1/4 times, your have 3.23's. If it rotates 3 3/4 times, you have 3.73's. And if it rotates just over 4 times, you have 4.10's. Hope this helps.
I used this
http://www.streetbeatcustoms.com/AM-...-50045/642935/
same thing basically, it worked perfectly on my 97 mustang but I would go with the handheld tuner if you can afford it.
