Which Plugs?
Old May 17, 2011 | 06:43 PM
dan03gt's Avatar
dan03gt
Default Which Plugs?
Can anyone recommend which spark plugs i should by? I have an 03 GT just hit 75K and plan on replacing plugs with coils in the next month. Current mods being flowmaster cat back. i plan on installing CAI, headers, mid pipe, throttle body and hopefully a custom tune over the next 6-8 months.
Old May 17, 2011 | 07:14 PM
wanttogofast's Avatar
wanttogofast
i put the e3 in mine and they work great
Old May 17, 2011 | 08:18 PM
WannaBeGearHead's Avatar
WannaBeGearHead
Go Texas!!!
I just installed NGK TR55s and so far so good.
Old May 17, 2011 | 08:42 PM
oxfordgt's Avatar
oxfordgt
stock motorcraft, why pay more when you dont need to?
Old May 17, 2011 | 09:32 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
^+1, or Champion stk # 3401--basically the same, a single platinum plug--there is nothing you are planning (of for that matter on almost any streetable 4.6 2V) that requires anything else...
Old May 17, 2011 | 09:38 PM
WannaBeGearHead
Go Texas!!!
Cliffy...when I was searching around myself on this same question I read a lot of places saying to run 1 step cooler plugs gapped at .054". They said they can get more timing out of a cooler plug and "the car likes a cooler plug"...at truth?
Old May 17, 2011 | 09:48 PM
crysalis_01's Avatar
crysalis_01
Banned!
I've always run either Motorcraft Platinums or Bosch Platinum +4's...though most here tell you to avoid the Bosch's... I've never had any problems with them.
Just don't buy bargin bin "Bob's Spark Plugs" and you should be fine.
Old May 17, 2011 | 11:38 PM
Repzard's Avatar
Repzard
One word.
Motorcraft cant go wrong with OEM's
stay away from the Bosch Platinum +4's ..theyre junk !!! Sorry crysalis but I had very bad experience with them. Plus theyre not made for our cars.
Old May 18, 2011 | 03:42 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
It depends on whether or not the stock heat range plugs are running too hot--this can easily be determined by "reading" them after making one or more runs at the throttle setting/range you are targeting. To do it properly you make the run and then shut down the engine, stop and pull the plugs--we did this all the time on drag bikes way back when there was no other way of electronically monitoring anything.
There are colour charts out there that have been around for years, most of them are incorrect for modern EFI engines where the plugs should be a bit lighter tan than most charts show.
As to a cooler plug's offering an opportunity to run a bit more advance, it might; however unless the original plugs were way too hot (nearly white looking) the gain would be quite minimal. If the original plugs were of a proper heats range you would perhaps lose a bit of MPG with no power gain at all.
One other comment, there is no standard for heat range classification of spark plugs, neither a general range or steps between ranges--each maker uses their own scale to rate their plugs, and provide cross references to other maker's plugs. So, just because NGK says that there heat range X is the equivalent to Motorcraft's Y doesn't mean it's an exact match.
This is particularly true when comparing fine-wire and conventional electrode designs where the heat dispersal characteristics of the two designs are quite dissimilar.
Last edited by cliffyk; May 18, 2011 at 08:00 PM. Reason: early morning atrocious spelling and other f'aux pas...
Old May 18, 2011 | 05:14 AM
uberstang1's Avatar
uberstang1
Chupacabra
I've been running autolites since the dawn my drivers liscense, no issues.
