'96 Coil Pack Testing
Old Jun 22, 2011 | 10:50 PM
tron2003's Avatar
tron2003
Default '96 Coil Pack Testing
I've got a stumbling / intermittent miss on my '96. I'm going through the checklist of symptoms and checked the coil packs. Remember since this is a '96 I have the (2) 4 coils packs not the COP's.
I check the primary resistance and it's within spec, it reads out @ .9 ohms on both packs and spec is .3 to 1.0
I check the secondary resistance and I'm coming up with anything from 13.1k to 13.25K ohms on both packs. Spec is 6.5k - 11.5k ohms.
Do these usually fail out on with the secondary resistance? I'm just questioning my results as it seems weird that both packs would fail simultaneously. Any thoughts?
Old Jun 23, 2011 | 08:52 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
Testing winding resistance, particularly the secondary, with a low-voltage ohmmeter is only a rudimentary manner of checking a coil, as it does it's works at 10s of kilovolts--however that yours are that far off the spec is not a good sign.
To test it properly get an adjustable gap tester.
A good coil pack should be able to fire across at least a 8-10mm air gap, anything less than that and it is weak. A stock Ford COP can fire across a 16mm gap.
Dathan
Oct 5, 2015 05:52 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
Sixer4Life
Sep 28, 2015 07:05 AM
