Needhelp quick! (mid pipe)
Old Jul 21, 2011 | 06:15 AM
JokerJinx's Avatar
JokerJinx
Default Needhelp quick! (mid pipe)
I am have a MAC O/R H pipe but it has the remnants of an O2 sensor from another mustang. I could not for the life of me remove, stuck in one of the bungs. The head is rounded off pretty good so I was thinking it may need to be drilled out? any idea? needs to come out today!
Old Jul 21, 2011 | 08:35 AM
trailor's Avatar
trailor
Did you try using PB Blaster on it? or at least WD-40? Any kind of penetrating fluid should help with the removal process. If the head is too rounded and you cant even get a wrench on it, try using vise grips. If that fails, you can either drill thru it, as you suggested, which is kinda risky, or you could shave/saw/sand down the exposed end of the sensor to where its almost flat and weld on a nut. If you don't have any easy way to get it welded on there, JB weld could possibly work. I've heard of some JB weld products that adhere pretty well in only a few hours. Anyway, good luck!
Old Jul 21, 2011 | 05:43 PM
Blackvenom01's Avatar
Blackvenom01
heating it will also do alot
Old Jul 22, 2011 | 08:29 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
^+1, use an oxy-acetylene torch to heat the bung up to cherry red--grab it with vise grips and spin it out. Any exhaust shop should be able to do this for pretty cheap, they deal with it every day...
svfetter
Oct 5, 2015 11:39 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 25, 2015 06:30 PM
Sep 24, 2015 09:18 PM
