tuner help. please
i used the search button and really didnt find what i was looking for. i have a 03 gt with bbk shorty headers, bbk chrome cai ,offroad x pipe and slp loudmouth catback and gears. im looking for a hand held tuner, what is the best one to go with and how much hp and tq to the wheels should i exspect? if i went to a local chassie dyno to get tuned what should i exspect? thanks guys
It really doesn't matter which one as they are pretty much all alike. That said, if you are not planning on doing you own tuning then buy which ever system the local shop uses--which is likely to be SCT.
If you do plan on tuning it yourself then the best value system is Delta Force's Commando. It's not a "handheld", but a PC based system that allows you to alter any aspect of the tune.
As to power gains, other then the X-pipe and catback you haven't done anything that will gain a lot; the shorties may add a bit, the CAI adds nothing. I would expect that with a well done tune, optimised for premium fuel, you would be at 235 to 240 rwHP peak, with more noticeable but similar percentage increases in the mid-range.
An after market upper plenum and 70mm or 75 mm TB would gain another 10 to 12 rwHP at peak and extend the usable power band right up to the rev-limiter, with again a noticeable but lesser percentage gains in the middle.
well with the mods i have, and the ones im going to buy here soon, i hopeing for 300 rwhp, 75mm tb, accufab upper, cams, ported heads, underdrive pulleys and replace the plastic intake for a alum one
With cams, ported heads, and a good tune its possible. Without the cams or heads you wont come close.
Are you planning to do your own tuning or pay a shop? If the former then I recommend Delta Force Commando...
mungodrums
Suspension
Sep 24, 2015 10:12 PM
