2004 CObra Front Sway Bar?
Old Sep 5, 2005 | 05:21 AM
yellow02gt's Avatar
yellow02gt
Default 2004 CObra Front Sway Bar?
I was thinking of buying an 04 cobra sway bar for my 2002 GT, does anyone know the width of the cobra sway bar, and is there and benafits with using it with my GT over the stocker
Old Sep 5, 2005 | 06:18 AM
01yellowgt's Avatar
01yellowgt
Default RE: 2004 CObra Front Sway Bar?
GT sway bar is 25mm, the cobra is 29mm. There will be less body roll with the cobra sway bar compared to the GT sway bar. And possibly it will also get rid of some of the understeer?
Old Sep 5, 2005 | 12:07 PM
IWinULose's Avatar
IWinULose
yellow02GT... not to Hijack... but I have 2 questions for ya... what hood is on the yellow mustang in your sig? and also, could you please measure the width of the hole on it? thanks!
Old Sep 5, 2005 | 06:17 PM
yellow02gt's Avatar
yellow02gt
ORIGINAL: 01yellowgt
Thanks for the info, do you know if there hard to install, i was thinking if I got the roll bar I would want some polyurthane bushings to stiffin it up some more, some like the energy ones, would i need the GT set or COBRA?
ORIGINAL: IWinULose
It's the svo type hood, and it's about 8 1/2"
Old Sep 5, 2005 | 07:17 PM
IWinULose's Avatar
IWinULose
Thanks, I really appreciate the info. I am looking for a certain hood I saw in MM&FF and can't seem to find it anywhere. I thought it might be the SVO hood with the stock GT scoop put on it... because I emailed MM&FF and they told me it was a custom piece. 8 1/2 inches doesn't seem to be quite big enough since the stock scoop is 18+".
Old Sep 6, 2005 | 05:50 AM
yellow02gt's Avatar
yellow02gt
Ya i know what you mean if you look at my hood, the lines after the scoop it almost comes to a point. while the GT scoop is parrallel. I bet you could make it work if you know how to use fiberglass.
Old Sep 6, 2005 | 01:04 PM
01yellowgt's Avatar
01yellowgt
changing the swaybar shouldn't be hard at all, just use some airtools. I cant speak from experience, but I cant see how it would be that hard. I would assume the polyurthane bushings for the GT, because they are assuming you will be using a aftermarket swaybar. I see what I can find out, but thats my assumptions.
Old Sep 6, 2005 | 01:11 PM
01yellowgt's Avatar
01yellowgt
never mind, it will be the 29mm cobra bushings.
Old Sep 6, 2005 | 07:34 PM
yellow02gt's Avatar
yellow02gt
i don't think that there would be a fitment problem when using the cobra bushing wiht the GT body, thanks for the info once again
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Sep 16, 2015 07:53 PM
Sparks_88
Sep 8, 2015 01:06 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Sep 1, 2015 08:16 PM
