back from dyno
Aug 24, 2011 | 04:29 PM
back from dyno
75mm t/b
bbk planum
42lbs injectors
svt focus pump
k.b boost a pump
l/t headers
o/r mid pipe
magnapack catback
302 forget stroker with 10.1.1 comp
comp 270 cams
minor clean up in the heads
vortech v2 10lbs boost
462hp 441tq 10* timing
Aug 24, 2011 | 05:01 PM
Up that boost! Decent numbers though, Definitely has a lot more left in it
Aug 24, 2011 | 05:13 PM
the plan is to add a meth kit and add some more boost around 14lbs going for 525 550
Aug 24, 2011 | 06:15 PM
Congrats Sash! Did Lidio say those numbers sound right with you mods at 10 psi? Either way it's a huge jump over before.
Now we need to get to the track. You up for it in September sometime?
Aug 24, 2011 | 07:09 PM
intercooled yet? If not, meth will make a HUGE difference
Aug 24, 2011 | 07:12 PM
Quote:
Originally Posted by
mrtstang
lidio was thinking 430-440 max,yes as soon as cool down ill go,on a hot day like this is not fun at all......
Aug 24, 2011 | 07:13 PM
97stanger
this is not inter cooled kit bud,yes i am looking forward meth injection.
Aug 24, 2011 | 08:18 PM
Aug 24, 2011 | 08:21 PM
What size pulley are you running? I just realized that you only have 10 degrees of timing. Did Lidio do that because you have no intercooler or meth or what?
Aug 24, 2011 | 08:37 PM
good numbers, with that meth you'll be able to run 16 degrees or more. she'll really wake up then!
