2002 lincoln continental 4v
Old Sep 27, 2011 | 05:50 PM
Dave19525's Avatar
Dave19525
Default 2002 lincoln continental 4v
I found a local guy selling a Lincoln Continental complete engine. He says its a 4.6l 4v. From what I have been able to figure out so far looks like he is correct. Wiring harness is missing and he claims low compression on #8 cylinder and he swapped motors rather than fixing this one. I am thinking of getting it and swapping the heads over to a current 2v motor, or maybe tearing it down and rebuilding so I will have a fresh 4v for a GT. What do you guys think? What is the possibility that the head is the reason for low compression? Its a pretty cheap price and I gotta believe the heads alone are worth what he is asking for the complete engine. Does anyone know which block this would be? Thanks for any help. 4v engine would be awesome.
Old Sep 27, 2011 | 06:03 PM
Dave19525's Avatar
Dave19525
I missed that this is a transverse mounted engine. Oops. That may rule out using the block for a rebuild into a GT, I will have to research that some more. But the heads should still work from what I can figure out. Has anybody done a swap with these heads? Will water pump, altenator, and other brackets still work?
Old Sep 27, 2011 | 08:19 PM
nickmckinney's Avatar
nickmckinney
Block cannot be used, heads are the same as all other 99-02 C heads.
Old Sep 28, 2011 | 05:51 AM
uberstang1's Avatar
uberstang1
Chupacabra
Its no good, the motor mount locations are different and so is the bolt pattern for the transmission.
Old Sep 28, 2011 | 12:20 PM
Dave19525's Avatar
Dave19525
Ok, so I understand the block won't work and typically its not worth converting a 2v to 4v. But with this being a complete motor, if I were to get a short block maybe from MMR or someplace like that, would all the stuff change over. Since it would be a short block and everything has to be bolted on it anyway I could just put all the 4v stuff on it and use these heads. Does anyone if waterpump, alt, tensioner all work or all not work for sure.
Old Sep 29, 2011 | 06:14 AM
uberstang1's Avatar
uberstang1
Chupacabra
the heads will go over fine, as far as the serpine belt assebly, no. the timing cover is setup different on the transverse mount 4v so the accessories fit snug in the engine bay.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
cr620
Oct 3, 2022 10:18 PM
mrtrodonet
Sep 19, 2020 03:12 PM
RCS02v6
Sep 29, 2015 01:46 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
