Powersteering
Old Sep 11, 2005 | 04:20 PM
Whitestang04's Avatar
Whitestang04
Default Powersteering
Well I went to the track on my new et streets last night. I have good news and bad news. First I got my time down to 8.896. The bad news is my car started leaking power steering fluid. I only did it when i went to heat my tires up and held it at high rpms. Its not a steady flow just leaks at high rpms. So I checked under my car this morning and its dry and I was wondering if its some kind of back pressure blowing it out or what. Has anyone else has had this problem before. I need to found out what it is before I **** everyone off at the track with this fluid leaking on the track. Thanks.
Old Sep 11, 2005 | 08:27 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
Default RE: Powersteering
Are you absolutly positive it was PS fluid?
Old Sep 11, 2005 | 08:58 PM
Whitestang04
yeap its red
Old Sep 11, 2005 | 09:02 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
Transmission fluid is red. My powersteering fluid is clear.
Old Sep 11, 2005 | 09:03 PM
Whitestang04
I also got my wife to turn the wheels back and fourth and reving the motor up and I coudldnt tell where its coming from. But its red and mainly around my power steering pump. I checked for loose lines and they are all tight. I was told it was from all the backpressure from the high rpms but I just wanted to get some more input on it
Old Sep 11, 2005 | 09:06 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
There shouldnt be an overflow from the powersteering. Is your car a 5 speed or an auto?
Whitestang04
Its in my front sway bar area which is right under my power steering pump and im bout out of power steering fluid too
Old Sep 11, 2005 | 09:07 PM
Whitestang04
5 speed
Old Sep 11, 2005 | 09:10 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
Well... I would definetly get under there and find the leak and not just forget about it. You have a 5 speed so you dont have a tranny dip stick... so I would be espically careful till you find it.
Old Sep 11, 2005 | 09:18 PM
Whitestang04
I am just confused on how it dont leak no other time but when i heated up my tires at around 5k. and when i pulled up it was bout 10 or 15 drops on the track. but when i just drive it and park at the house there aint one drop.
