Camber/caster adjustments
Old Jan 31, 2012 | 09:32 PM
vargas's Avatar
vargas
Default Camber/caster adjustments
So I took my car to get aligned and they "technician" said rack and pinion bushing are cracked (does not matter to me its a little rubber piece that ripped off) and theirs minute play on the inner tie rod (doesnt concern me either). I asked him to fix the caster and camber and he only corrected the camber by .2 degrees. So I now am deciding to move the camber plate out more to correct the negative. Caster is Positive.
Does this mean for caster to be correted, I would have to move the plate to the front of the car? I understand negative camber has to be corrected by moving the plate towards the outside of the car.
Old Feb 1, 2012 | 07:45 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Yes... negative camber is decreased by shifting the plate toward the outside of the car. Positive camber is added by moving the plate toward the back of the car.
Depending on your driving needs, a little to a lot of negative camber is a good thing, although it can be hard on the inner edge of tires. Adding caster is nearly always a good thing, in that it helps to maintain a larger contact patch of tire on the road surface. Especially if one is running wider than OEM tires/wheels up front.
Are you into harder cornering, 1/4 mile or just DD duties?
Jazzer
Old Feb 1, 2012 | 01:19 PM
TRUEBLUE3934's Avatar
TRUEBLUE3934
I am slightly confused by your use of the phrase "to correct" the caster or camber.
As JAZZER mentioned, their are benefits to both caster and camber. Why are you trying to adjust your settings yourself? It is a shame to pay for an alignment and then immediately loosen the nuts and start moving the setting around.
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
