Cooling system help please
Old Mar 14, 2012 | 03:21 PM
Bullitt AK's Avatar
Bullitt AK
Default Cooling system help please
so i flushed the system by removing the thermostar and lower rad hose only. ran an additive and then flushed it the same way again. hooked it all back up and i can only get 1 1/2 jugs of straight antifreeze in my system? i let it run...it burped a bit and i put more antifreeze in...i drove it around a bit and it didnt overheat or anything but the level stayed where it was in the overflow.
also my tester is reading -10 degrees freeze protection...would this mean i need more water or more antifreeze? and is the measurement supposed to be taken when its warm or cold or it doesnt matter? thanks alot
Old Mar 16, 2012 | 09:35 PM
Rad Red 03's Avatar
Rad Red 03
First of all, why did you fill with 100% anti-freeze? Check owners manual because Im pretty sure a 50/50 mix is all thats called for. If thats true then U need to drain some and add water to get the correct mixture. I know on my 03 GT the coolant overflow has two lines on the side, one for cold and another hot. Look close, its hard to see sometimes. Also the owners manual will give you all the liquid capacities. If your car is in fact a Bullitt then the manual should be your friend. If you dont have it then check it out online, just search for the Tech specs on your car.
Old Mar 17, 2012 | 09:21 AM
FlamingoGT's Avatar
FlamingoGT
My handy-dandy book says 14.1 qts of 50/50, which would be a hair over 3 1/2 gallons. You didn't drain it the recommended way... how much fluid did you get out?
Old Mar 18, 2012 | 05:45 AM
Bullitt AK's Avatar
Bullitt AK
yeah i didnt remove the plugs i was under the impression that i could get it all out the way i did it which is why i was going to use 2 gal os strraight then the rest water but i never got that far because it wouldnt accept more is why was using straight...ive corrected it with a hydrometer thanks
Old Mar 18, 2012 | 05:46 AM
Bullitt AK's Avatar
Bullitt AK
mine says 16.9 quarts =/
Old Mar 18, 2012 | 10:57 AM
FlamingoGT's Avatar
FlamingoGT
My book has been wrong about other things before and in this case didn't differentiate between years or sub-models, only between V6 and V8... but it was still an indication that if you only got about 6 qts out then you were no where near getting all of the old fluid out.
Old Mar 19, 2012 | 10:21 PM
SXGT's Avatar
SXGT
pure water will damage it just as bad too, thats how i cracked my thermostat housing a year ago. The hot water is like sand paper on the plastic, and pure anti freeze is corrosive to the metal, or something. my line is corrupted and always a nasty brown orange, even after flushing it with Peak. But that also may be from where i used leak stop.
50/50 even in summer time.
mrtrodonet
Sep 19, 2020 03:12 PM
bradleyb
Nov 27, 2015 07:50 PM
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
