Intermittent starting problems
Old May 3, 2012 | 05:47 PM
todd in atlanta's Avatar
todd in atlanta
Default Intermittent starting problems
Have been having some starting problems lately, I turn the key to crank it and get nothing, no clicks, just nothing. Replaced the battery a few weeks ago, had same problem again, thoroughly cleaned some corrosion on cables, have not had problem for a few weeks. Today it happened again, found a guy to help me jump, started after awhile - got home, did it again, on the second try it started. Based on my earlier search on here, not thinking it is starter, those I issues all mentioned a click. Any help would be greatly appreciated. The car is a 2003 GT convertible, automatic
Old May 3, 2012 | 05:55 PM
03gt04mach1's Avatar
03gt04mach1
Could be the Alt not charging the Battery. The battery may run the car for a while till it dies, but not getting charged. I'd have both tested at an Autozone or Advance Auto, NAPA etc. I'm not sure that's the issue here. Could be bad cables since you talked about cleaning off corrosion.
Old May 3, 2012 | 07:20 PM
todd in atlanta
Have pretty much ruled out Alt. Other than cables, is there anyting else that anyone can think of? Also, what is the best source for replacement cables? Autozone and Advanced just sell generic ones, Ford's are huge dollars last I checked - like $300
Old May 3, 2012 | 07:37 PM
JeremyB's Avatar
JeremyB
Check the grounds on the bottom of the car, there is one on each motor mount going to the fender, make sure they are tight
also check the connection going into the fuse box, make sure it is tight
Old May 3, 2012 | 09:23 PM
todd in atlanta
Will do, thanks for the reply
djbigskrilla
Sep 20, 2022 01:04 AM
Spiral534
Oct 6, 2015 04:31 PM
jjwinel78
Aug 17, 2015 03:34 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
Pain.
Aug 7, 2015 10:48 PM
