Help Please!!!
Old Jan 7, 2013 | 03:26 PM
Spray's Avatar
Spray
Default Help Please!!!
Hey guys , I am new to the forum world. But I drive a 2000 GT. The SES light is on and it says it is the camshaft position sensor. I changed it along with a PA Performance 130 AMP alternator. The light is still on and my car is falling on its face around 4000 RPM. I have a 4.10 gear. Can someone please help me? I have no idea what could be causeing it and I do not have the money to take to a shop. Thanks! Much appreciated.
Old Jan 7, 2013 | 04:27 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
What was the trouble code?
Old Jan 7, 2013 | 08:56 PM
Spray's Avatar
Spray
P0341
Old Jan 7, 2013 | 09:09 PM
Nyke's Avatar
Nyke
Check the wiring from the sensor and on, it may have shorted, grounded, split itself. If you have a multimeter (Volt OHM meter) you can test the sensor. Also make sure the cam shaft position gear is not damaged, it is a gear on the cam shaft that generates the signals for the position sensor, if it has a chip or a missing tooth it will put that signal on.
cliffyk's Avatar
cliffyk
TECH SAVANT
Are you certain it was P0341 and not P0340? I ask because though P0341 is defined it is not generally revealed as a persistent code--it is not even mentioned in the shop manual, you have to go into the tune's source code to see it.
In any event it is a Cam Position sensor error--click here to see the possible causes and diagnostic aids. I realise you stated you had replaced it; however that does not rule out that it might be defective even if new, or that there may be a wiring problem. Check all fuses to make sure they are good--pull them out and LOOK at them, best yet pull them out and check them with a continuity tester--do not rely on other means. Vibration over the years can cause fuses to develop fractures that increase their resistance and limit current flows.
This is not common, but then again you are trying to track down a problem that regular "experienced" mechanics do not seem able to find...
Old Jan 7, 2013 | 09:18 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Without a multimeter, and the KSAs to use it, there is no chance of tracking down this problem. I do not mean to be harsh, but that's the fact Jack...
Old Jan 8, 2013 | 11:55 AM
Spray's Avatar
Spray
Yes I ment to put P0340. We checked the sensor with a multimeter and it is good. I am about to check the wiring and the gear. Could this be a possible cause of it loosing power around 4000 RPM? Thanks for your help guys!
Old Jan 10, 2013 | 10:15 AM
Spray's Avatar
Spray
I started to look at the wires and i do not know how i did not catch it when i first changed the cam sensor but it was cut. It could not have been fixed because it was to close to the peice that pluges into the cam sensor so I went to a junkyard today to get one. They did not have any GTs so I pulled one off of a V6.Hopefully it works, if not then I am out $2
Old Jan 11, 2013 | 12:32 PM
Dudewright0715's Avatar
Dudewright0715
Hey man watch out PurpleIcedGT may get mad that you put !!!! On the title of your thread.
Old Jan 11, 2013 | 10:54 PM
Spray's Avatar
Spray
Get mad? What? Oh and to everyone else, it fixed the SES light but not the stubling at 4000. I'm pretty sure it has something to do with not getting enough fuel.
