drag coefficient
Ive never had a car with a hood scoop and I must say, it gives me the feeling that I am not very aerodynamic... past 70mph my hoods shaking even...
has anyone payed any attention to MPG because of hoods and stuff? Also how can you look up your drag coefficient? there can t be one magic number for all mustangs. I can think of 4 different hoods... :icon_rain: EDIT: I dont want to make another thread so I will ask in here. Am I a crappy driver? here is why I think I might be. When going WOT and shifting into 2nd I spin the tires a LOT, tooo much i think. I just got new tires and they should be gripping better. I feel like I can feel the tires start to lose traction at about 5K RPM tho before I shift and i think me shifting is making it worse. I have 275mm Nexen N7000s in the rear... |
Why are you going WOT on the street?
Tires, suspension and road surface will be the three factors to hook. I could spin tires in a stock V6. You have to drive it smarter. Over powering the tires will slow you down. If you are really worried about aero, the scoop is a start - but in the big picture, it's just the tip of the iceberg. |
Those nexens arent the best tire to begin with
Originally Posted by uberstang1
(Post 8173378)
The car has alot of power its just not alot by todays standards, definatlly more than enough to break those tires loose on a rwd mustang. Just cause its 275 means nothing, quality of the tire means more, a top end 245 would hook better than a low quality 275
(Post 8173430)
I know these cars are light in the rear, and if fuel tank is under half it doesnt help spinning either. As for the hood scoop, its not enough drag to worry about. |
A GT hood scoop has minimal effect on CD. When program manager Scott Hoag wanted a functional shaker on the 2003-2004 Mach1, he had to prove that it would increase performance. Testing showed a ram effect above 80 MPH, so the Mach 1 got its real shaker.
Under 80 MPH, there is little if any air being rammed into the shaker. Essentially, the nose of the car pushes most of the air above the hood higher than the shaker. Your GT hood scoop is lower than a Mach 1 shaker and I'm betting it has very little if any effect on CD below 80 MPH. I doubt any aftermarket hood that is less than eight inches higher than stock would affect CD below that speed unless it was eight inches higher at its leading edge. I've driven New Edge GTs, both coupes and convertibles, and never noticed and hood shake at or below 120 MPH. I can't remember driving a GT over 120 MPH. If you want to lower your CD, get rid of the 275s and go back to the stock 245/45 17s. What exactly do you mean by spinning the tires shifting into second? Are you getting a chirp, or lighting them up? Are you power-shifting? Doing something unnatural with the clutch? I can accelerate WOT in my Mach 1, shift normally into second and immediately resume WOT and chirp the tires. I let up on the accelerator and use the clutch and my 275s are "not spinning." I'm pretty sure I could get my rear tires to spin a whole lot more shifting into second by driving like idiots on YouTube videos, but don't. It isn't faster and only leads to blue and red flashing lights. |
If you grab second real hard and keep the RPM's up high during the shift you will spin tires all day. It is the shock to the drivetrain that breaks the tires loose.
You could continue to powershift and ride the clutch a bit, at the expense of your clutch disk of course, to give it a smoother transition. |
Originally Posted by Stevo86
(Post 8173553)
You could continue to powershift and ride the clutch a bit, at the expense of your clutch disk of course, to give it a smoother transition. That pretty much is my definition of driving like idiots on YouTube! :icon_bump1: I'll start trashing my transmission, clutch and tires after I get a sponsor to pay for parts, labor and a new car. |
Originally Posted by Sonic Mustang
(Post 8173531)
Im pretty sure I could get my rear tires to spin a whole lot more shifting like idiots on YouTube videos, but don't. It isn't faster and only leads to blue and red flashing lights.
(Post 8173694)
